Honda seat not clipped in.
7.4K views 14 replies 7 participants last post by  jmiller284
I just noticed that my front seat clips that the leather seat cover clips in wasn't clipped in. If you look at the gap between the seat and the middle on both driver and passenger seats. I will add a picture but it's not the greatest. I clipped them in. Also the 2 second row captain chairs under the front they weren't clipped in either. I will add a picture of it unclipped and clipped. Anyone else with this?
Sent from AutoGuide.com Free App
#2 ·
The underneath clips are very easy to put back together just make sure you try to stretch it as far as you can get it.
On the other hand the clips between the seat and the middle console are a pain to get back in. Keep trying you'll get it. It takes a little bit of patience and really small hands. Try to use your second hand to pull the seat away from the middle console.
#10 ·
I looked underneath the Passenger side seat and that clip is set closest to the edge of the "grating" underneath. On the Driver side if I attach to the same equidistant edge it's a "loose" set, so Driver versus Passenger side the underside engagement points aren't the same. I would expect there to be symmetry between L and R sides.
#12 ·
It should stretch to the end of the elastic. Pull hard.
I’m going to be unrolling the passenger seat this weekend to install the aftermarket armrest on my passenger side. I’ll try to take a pic.
