I replaced three of these actuators (2 front and 1 rear) over the weekend on a 2003 Pilot.
Expect to set aside at least 1-2 hours on the first replacement, lesser time on the ones afterwards. Be careful not to push parts in directions that they shouldn't be pushed in. Don't break any plastic parts/metal rods or connections - take your time.
1. Remove the plastic tab under the inner door latch.
2. Open the 2 small black colored screws.
3. Carefully swing the door latch attachment out by moving it down and out. Remove the rod and the electrical connection - there's a slot to press and pull-out.
4. Use a flat screw driver to carefully pry the window opening plastic area (its one piece and includes the cup holder). Remove the electrical connection - there's a slot to press and pull-out. Open the screw beneath the arm rest.
5. Use a flat tool (I used a metal putty 5-in-1 tool) to slide between the door metal and plastic areas - pull the plastic buttons/connections off, you'll hear them pop. Slide the door out.
6. Gently open the white plastic sheet about a quarter of the way from the top right down so you can reach in the actuator area (near the door latch - at the end of door with 3 screws). Open the window guardrail, if its in the way - use a 3/8 bolt.
7. Use correct amount of force, without stripping them, open the 3 screws at the door latch.
8. Take a good look at the connections inside. Open the electrical connections (two of them) on the lock actuator.
9. Gently but forcefully (without breaking any plastic or other parts), push the metal connectors back and carefully remove the door lock actuator assembly from the door.
10. Replace with new actuator and assemble in reverse.
To Yeshua be the Glory!
