I you plan to install an aftermarket amp or sub to your audio system, you will quickly learn that it doesn't play with the Pilots ANC (Active Noise Cancellation). The good news is that it is possible to disable the ANC by disconnecting the front and rear ANC mics. I've provided detailed instructions with photos for you. Just view the photos in order. First we will cover the Rear mic then the front in the next post. If you have question, just respond to the post as I will monitor it.
-Joe
-Joe
