When choosing an oil filter more important is filter efficiency (Beta Ratio) and dirt holding capacity not bypass setting. If you want great filtering/clean oil for an extended oil change interval (15,000 or more miles) you use Fram Ultra (99%@20 microns). You can add to this category Mobil1 EP and probably some other so called boutique oil filters like Amsoil, Royal Purple etc.). If your oil change interval is up to 10,000 get WIX regular, STP Xl (Autozone), NapaGold, Microgard Select (O'Really), Fram TG etc. These filters are good up to 10,000 with good efficiency of 99%@23 microns.
Use Wix XP only if you like dirty oil in your engine for an extended oil change interval. Its filtering performance is 99%@35 microns or 50%@20 microns. Regular Wix is 95%@20 microns and Honda is 62%@20 microns. Does all that matter? I do not know but I know that I used Fram COD for over 300,000 miles on my both Nissans (conventional oil, 3000 mile oil change interval) and sold both with perfectly running engines.
