1 - 20 of 155 Posts
Got a 2004 with 235k on it and giving it to my daughter and have read a ton of articles on here but not many ones recently about oil filters. From other sites, it sounds like a lot of good brands and models have gone to cheap construction and cutting corners from what they were always known for.
I'd just like to find the right (current) filter and get a case and be done.
Thanks!
Thanks!
For the most up-to-date information, I'd be looking on Bob is the Oil Guy forums. While we may have some good conversations on here and some knowledgeable members, that's all they do over there.
2007 EX 4WD
I'm using the Bosch 3323 for my Pilot, and the OEM (15400-PLM-A02) for my CRV (while it's under warranty). The holy grail of filters is no longer being produced, the Honda 15400-PLM-A01 made by filtech.
With the exception of the s2000, Honda engines don't seem to picky. It seems just about any filter is fine in the J35s.
But I do agree with @cintocrunch, BITOG is loaded with opinions, some of them even based on facts.
Super Moderator
Things and brand quality can change over time. I typically use Purolator, Wix, Mobil-1 etc whomever is on sale. Regular oil change intervals with synthetic fluids help keep my Pilot healthy. No need to buy a case as a few on the garage shelf should suffice.
Home of the 302k 2012 V6 Honda Crosstour
After experimenting with several, Wix XP or Napa Gold are very well made filters. Made with synthetic fibers. For more bang for the buck, I use Wix 51334XP. It is about 16% larger than the 57356XP and has the same bypass valve pressure rating as the 57356XP at 9-11 GPM.
Some filters are higher (not a good thing). If the bypass doesn't open if filter clogs, there is a risk oil pump spring relief valve failure.
I avoid economy priced filters. I'd at least buy at mid price range.
Miss our 2005 Pilot
You can also check YouTube videos for the latest oil filter comparison. I recently watched one where the guy cut open a good handful of conventional and synthetic oil filters, and it was very educational. It showed what the cheapie filters are made from (avoid those) and that a high cost filter doesn’t necessarily mean better quality materials were used in its production.
As I always say, I change my oil filter every oil change, and I use.....
Drum roll please......
SuperTech- the Walmart brand. They have good reviews, and they're cheap.
Reactions: 20Piloteer07
I'm not confident that this reduced size filter last 5k miles before the bypass valve will need to open.
for years I used to run purolator on my Jeep. on my honda's I run fram ultra. been running the SAME filter on my civic since the first oil change was done by me and every subsequent oil change. I will have owned the vehicle 10 years at the end of the month, no oil related issues.
guess I should have been more specific. not literally the same filter has been left on the vehicle for 10 years but the same part number canister is replaced at every MM dash light notification :LOL:
2006 Honda Pilot EXL, 3.5L 5 speed
I stick with OEM filters. I buy in quantity on Ebay or even the dealer. They are a far better deal than what you get at Wal Mart or Autozone. I change oil every 5k, so filter media, while important, isn't a deal breaker.
If I insisted on a Honda filter, I'd want to make sure it's genuine, making sure it was sourced from a dealership.
Product Font Material property Liquid Gas
Or maybe not.
The oil filter that I use and serves me well is the Mobil 1, M1-110A. I use this filter in my Pilot, '12 Civic Si, and '10 CRV and it hasn't failed me yet. I've cut open a few of them and they've all been clean to what I could see. They typically see from 5K-15K per change and I couldn't be happier with them.
I could have sworn I saw a Project Farm video on oil filters, but for the life of me I can't find it. Need to work on my Google-Fu.
Organism Primate Terrestrial animal Toy Font
But for me it's usually Mobil-1, Wix or the most expensive Fram, whichever's on sale for cheap.
Or maybe not.
Reply to my own post.
What's interesting about this website is the photo says Made in Japan but the manufacturer is some where else.
Reactions: headknocker
Project Farm has tested both air filters and motor oil, but so far doesn't seem to have tested oil filters.
@Nail Grease seems to prefer the Wix XP oil filter - with the leaky pressure relief valve.
I'm in no way for or against WixXP. I use there filter quite simply because of the synthetic fiber media, and the decent price I can get by buying in bulk quantities from RA. What I think is unfair about the test is that he plugged all the other filters, not doing the bubble test relying on their own bypass valve. He could have plugged the end of the Wix to get a more accurate comparison with the other filters. Remember too, he is forcing air in the opposite direction than the oil will flow.
You always try to find fault with the testing procedure when the outcome doesn't favor the products you choose to use.
Same for tire tests.
1 - 20 of 155 Posts
