41 - 60 of 106 Posts
This is very interesting. A discussion of Honda GDI engines and intake valve deposits really deserves it’s own thread. I am not aware of a significant problem with the Earth Dreams V6 valve deposits, but I’m sure someone will have something to say on the issue.
Is the “earth dreams “ engine only the third gen ?
Well, it was implied that the aftermarket are categorically worse. From the hundreds of Youtubers who've torn apart OEM and aftermarket filters, the OEM are as often than not, the more (or as) "cheaply made", which doesn't surprise me. Pennies turn to millions. Now whether those superficial "can you believe they use cardboard, or sloppy glue, or only have 190SQI of filter media...or..." have any material impact on the filtering performance over the life of the filter, or notably engine performance/life, no one here has the means to peform the controlled tests and say.
So yes, I think you have an up hill battle arguing (anecdotally) the OEM filter is usually (or in this case) superior to the better after market choices. And that Honda won't change vendors or some bean counter relaxes specs. Maybe we can get the Project Farm guy to do some controlled testing. He might have a shot at repeating J806 or J1858.
I don’t want to argue with you or anyone. People believe what they are going to believe and this exchange is no longer useful. I am reminded of prior exchanges on how valve adjustments aren’t needed and aftermarket timing belt kits are just dandy. It’s one of the reasons I no longer buy used cars.
If we're talking about the direct injection engine that's in the 3rd gen, yes, I believe that there is a problem. Not everyone thinks there is. Here's what mine looked like...
Right but it is made to Honda specifications and has to meet their testing to assure it meets specification, irrespective of the firm that makes it.
If you are saying you are a better judge, then you must either be an engineer in the field or you should get rid of the Pilot, because if a layman knows better than a manufacturer’s engineers, the car is by definition a POS. I would say this on any brand.
At the end of the day, an aftermarket filter may be fine but again what are the savings? This is more now about psychology then engineering.
Yes - Honda provides a set of minimum specifications and bids out the production. Honda isn't looking for "the best possible product" they're looking for something that's good enough and meets their specs. There have been plenty of times with plenty of manufactures where "good enough" isn't as good as the aftermarket can produce. The Fram Ultra Synthetic filter I buy costs more than the OEM filter. I run it because I've seen inside both of them, researched the specs, and feel like the Ultra Synthetic is a superior product. Kind of like tires - the Michelin MXV tires that came on these cars were certainly adequate but as I think we've all discovered there are better options available. Of course you can also buy a lot cheaper tires too.
Reactions: AVC
Hmmm... No fuel to wash the oil off the intake valves? maybe it needs a separate oil filter for the PCV system? j/k... Though a good intake-tract cleaning (Seafoam, Berrymans, water/steam) might shock a lot of that junk into the cats...
Filters:
A recent "engine masters" (discovery channel program) featured a shootout among major oil filter manufacturers. The K&N Gold was their top recommendation. Rated for finer particle removal, still had full flow and min pressure drop in their tests. They didn't actually measure the particle filtration size in the test though, just flow and DP.
I've been using the Bosch Distance D3312 filter intended for the S2000 engines since the car was new. The filter is slightly longer with more filtration area than the standard size, has a higher burst pressure rating (not that that's important really), and was at the top of a ratings pile when I got the car. I have one left of the 12/case I bought in 2013, scheduled for use this coming fall, so I started looking at options. One is the standard blue Honda-branded filter, currently manufactured by Honeywell.
In one of my little spare time consulting gigs, discussions move to oil flow, temperature, filtration, and moisture content as they relate to vibration in large rotating machinery with plain or tilt-pad bearings. Amazingly, suspended particle size in the oil doesn't make a lot of difference in wear between 50- and 100-micron filters. Flow makes a difference to the point when there isn't enough to maintain a wedge/dam to float the shaft. Biggest issue by far is moisture, where not that many PPM results in vapor bubbles expanding and collapsing, interrupting that same wedge/dam that supports a shaft in a plain bearing.
So, do I need to spend up to get a 50-micron rating oil filter in my Pilot? Or will the factory-recommended 100-micron media be enough? I haven't cut open a Pilot filter in years, nor sent an oil sample for analysis as I have for some other cars. Maybe one of the joys of the Honda is that I just don't need to worry about such things. I change the oil very regularly, use a known good oil and a known good filter when I do. It seems to use virtually none between changes, otherwise runs perfectly, is great on fuel while I drive it like the old white-haired guy that I am. No reason to change what I'm doing, based on evidence gathered so far.
And, FWIW and as predicted, we are straying way far from the OP's question. I know I'm as guilty as anyone. Just sayin'...
Reactions: STMech and AVC
Filters:
Not all Honda filters are made by Honeywell.
Yikes 😳 I wonder what my direct injection in my sky looks like at 114,000 miles now
I have heard of walnut shell blasting to clean it up but seems like a messy job
I've read the Pilot tends to stay pretty clean even up there in miles. The N54 is kinda known for NEEDING walnut blasting at 50k.
“Top Tier” ?!? Do you work for chevron or something ? LOL
Good ol Kirkland signature gas here
You mean this "Chevron" Gas???
The Approved Top Tier fuel brands.
Hey wow thank you - I watched that video on top tier and now I understand it’s not just a name brand gimmick - I m sure it’s more pricey though and considering todays prices :/
Oh sweet - Kirkland is on the list :)
I wonder if that list is too old to include “speedway”
Curious, says Honda and Made in Japan; available in 1000 pc lots from China.
Obvious, shameless fake.
The only safe way to know your getting Genuine Honda is to buy at the dealership or a website parts department that's based in a dealership. Anywhere else could be counterfeit.
I agree. I suspect that these Chinese made filters are the ones that you can find on EBay for a bargain price. They may be adequate filters, or maybe not. There would be no way to tell.
Yep, I'm now on the bandwagon that it isn't really the oil = use any name brand full synthetic - but rather the filter - for example, perhaps Fram does impede flow - hence, I only get the filters from the dealership (and the new crush washers) (and I get a new plug once a year as well).
