So what brand engine oil (0w-20) does everyone use? I’m looking to do it myself, thanks.
Is something like this what you're referring to? This must be really old ... pre-sunglasses. Price on Amazon doesn't seem too bad, especially if you install the Capital One discount extension on your browser.There isn't nearly enough pressure to support DI. For port or throttle-body injection nozzles the fuel pressures are typically well under 100 PSI, so air from a common compressor is plenty to get the cleaning mixture moving through.
Clever idea! $19.95 sure beats $180![this pulls the OP futher off topic, so not offended if this post gets moved]]
I used this setup for both the Pilot and my Mazda (DI). The Pilot fuel line is simple to separate at the cowl. My Mazda has a disconnect right before the high pressure pump. I use my air compressor to pressurize the canister (with a metal locking air chuck, now) and its onboard regulator set around 30 psi; it's lower than the nominal 60 to 70 psi from the low pressure pump, so it forces the PCM to use longer injector open times during cleaning.
The canister is one of these:
With this added to a drilled & tapped hole on the bottle cap:
I am going to proper weight, from now on.You may want to reconsider putting that heavy oil in the Pilot. It may be working but it's not good for the engine. It would be a strain on the oil pump.
It doesn't change the total volume dispensed for a firing cycle but it does improve the dwell time (chemical reaction time) of the fluid through the pintle, per compression cycle. I got this from some study years ago, re: parameters for those injector cleaning stations and strategies they use, that would apply to on-vehicle cleaning. With a fixed volume of cleaning solution, cleaning is often more effective with larger dwell times.Having more injector open time as some suggest, with running a lower rail pressure, doesn't change the total mass of fluid passing through an injectors, at least while the PCM is in closed-loop mode.
