21 - 40 of 210 Posts
My VCM disabler has been on my car for only about 3 weeks. I don't have enough miles on it since installation to really have any real sense of any mileage differences between having it enabled and driving it as stock. This car is basically a garage queen and may see 4000 miles a year. But after doing what I considered my due diligence I came to the conclusion that a VCM disabler is a very wise choice. In my particular case (low overall mileage), the loss and cost of 1 or 2 mpg over time seems in line with cost of a new ring job and/or motor mounts. All at the same time of having a car that drives and feels so much better.
I guess someone could do the match.
Did you notice a smoother idle? When I first put mine in, I kept checking to make sure the engine was still running because it wasn't shaking like it usually did. I guess VCM kicks in at idle, but without the indicator lighting up. Also much, much smoother cruising along at 80 on the highway. It felt like a whole different car.
Oh, and I used to occasionally get random puffs of oily smoke out of the exhaust when I started the car. The dealership couldn't figure it out because it was intermittent and I couldn't reproduce it. Apparently that was VCM too, hasn't happened once in the 18 months since I installed it. I forget what the mechanics of it are, but I read that the cylinders not firing allows oil to accumulate in them or something, and then when the car starts with all that oil it all burns off.
Good riddance.
Discussion starter · #25 ·
Thank You Folks! S-VCM installed and so far, so good!
Be prepared, there is a decent chance it may fail a few years down the road. Seen it quite a bit with the S-VCM unfortunately. The symptoms it usually exhibits is strange temperature gauge behavior and stalling.
owns 2006 Honda Odyssey EX
Hmm, that’s a bummer, just installed mine a couple weeks ago. If the S-VCM is not a reliable unit, which one do you suggest? I went with the S-VCM due to the year round function, and the protection the unit supposedly provides if your car starts to overheat.
Discussion starter · #27 ·
VCMTuner II. Does everything the S-VCM does and more, plus it has generally been a better quality unit.
Reactions: ruvi
Thank You for the warning.......maybe in the future, I'll switch to the VCM Tuner II......let me have my $$$ back from having S-VCM....Again, Thank You!
I installed S-VCM and initially it rides smoother, it shifts smoother and coasting longer without engine brake effects, and definitely more power with less gas pedal use until yesterday.
Yesterday, I unplug the battery negative terminal and plug it back in within 2 minutes just tried out to see how it's done before leaving for a long term trip. (practice for the first time)
Now for some reason, it felt the same as before installing the SVCM. Jerky trasmission at certain gears, soft gas pedal and etc. It just feels like VCM is active again just like it went back to the way it was before the install.
Does anyone know the reason why or if this has anything to with the battery resetting? How to make it work again?
Thank you in advance
Discussion starter · #32 ·
Often when the battery is disconnected the car has to "re-learn" the way you drive. It sounds weird, but the car learns your driving habits and behaves accordingly. Give it some time and it should fix itself.
Reactions: JYOO
how can using more cylinders ever save gas mileage? maybe you use cruise control more often or are actually trying to save gas now.
It could easily be more efficient running all 6 cyls all the time. Spse for example the VCM causes misfires, as it's known to do. When those cyls misfire, that unburnt fuel mix goes out with the exhaust and you get nothing for it. Hence lower MPGs.
Discussion starter · #35 ·
Never updated the thread to reflect the 2023+ Pilot. Finally went ahead and did that now.
I don't know if the new implementation of VCM with the hydraulic valve tappets warrants considering it a new revision of VCM (VCM-3.5 or VCM-4), since it does still deactivate bank 1 only like VCM-3 does, only difference is how it accomplishes that. For now, I'm considering it as still VCM-3, but I'm open to input on this.
I am new to the Pilot group and my 2011 Pilot is the first Honda I’ve owned which I picked up in Nov 2022.
I knew it had a few front end pieces needing some attention. After I completed those repairs, I was still experiencing some odd noises and vibrations so feared I may have a bigger issue going like a transmission etc.
So I found and joined this group and oh my !! Was it too good to be true it was as easy as disabling the VCM-2? Well it sure had its issues more CONS than Pros, so a few weeks ago after reviewing several discussions including this one, I went with the SVCM. Night and Day !! Although previous owner recently replaced ALL wheel hub assemblies, I was still hearing all kinds of odd noises and vibrations which didn’t make much sense. Once I installed SVCM, almost ALL of them are gone. Especially the rear howl which its my understanding was prob the VCM and noises traveling down through the transfer case etc.
Although VCM was a good idea, VCM-2 was upon the worst version to date. Besides not knowing fully what temperature you may be running at, I can not see how this little device can be blamed for ANY engine or component failure !! The SVCM module claims to have enough smarts in this event, it would shutoff . We all know when the Idiot light comes on, some sort of damage may have already occurred.
Again I didn’t buy it to help with MPG, long term solution to ALL the negatives the VCM-2 presented. I am not in the market in replacing a failed motor, replacing spark plugs or adding oil. I pulled Diags and found an instance of a cyl #3 misfire so hard telling what was coming my way.
Saving all the added vibrations & stress to very expensive motor mounts, to vibrations to the transmission and Drive Train is a plus. My son who is a new driver could tell a Night and Day DIFF and so far I am not seeing any loss of MPG, honesty feel it might have improved slightly (Me being wishful).
Thanks for the support ! If any thing changes from this post I will let you all know (good or Bad)
I also purchased my 2011 in november 22 just like you... and SVCM has been a game changer. My mileage for my first 1000 miles was 17.8 and since SVCM install, I'm getting 18.5 over 1500 miles. Unsure if this is indicative of better mpg, but it certainly isn't worse.
Like you most of my vibrations are gone, but I still sometime feel a little shudder when letting off the gas. My next service will be changing out to maxlife ATF in the spring. Good luck with your new vehicle!
Discussion starter · #38 ·
After some deliberation, I have decided (at least for now), to classify VCM in the J35Y8 as VCM-4, and the megathread has been updated to reflect this.
When more is known about the new implementation, this may change, but for now, too much about the engine has changed to assume that it's very similar to VCM-3.
Discussion starter · #40 ·
Reactions: cintocrunch
