Leather Center Console Cover Replacment Review
Ok, here is the review of the leather center console replacment trim piece you can buy on ebay for about $45.
First understand all you will receive is a piece of leather cut out and stitched to be fitted over the console lid once you remove the original piece of vinyl.
The color match is excellent, the added stitching is a nice touch and looks more high end. I was very pleased with this solution and it is well worth the money and minimal effort.
Highly recommended upgrade/fix.
1. Completely removed the console lid.
2. Remove the 80+ staples that hold the original vinyl down with a small screw driver.
3. Use pliers as needed to pull the staples from the plastic console lid.
4. Carefully and slowly peel the vinyl cover off the foam backing of the console lid.
5. Position the new leather piece be sure to line up the stitching for the right fit.
6. Using a construction grade stapler (not an office stapler) staple down the edges with the stitching first so it does not shift, work from center out.
7. Do the same for the top and bottom console edges.
8. Reassemble and install.
I found this fairly easy as long as you took your time and worked the leather (pull and stretch) into the right spot.
It took me about 30-40 minutes start to finish and I rushed due to a baseball draft I needed to attend.
After I finished I immediately checked my oil
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://pic2.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http%3A%2F%2Ffeed1343.photobucket.com%2Falbums%2Fo798%2Fautoguy1%2FHonda%2520Pilot%2520Center%2520Console%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="javascript:void(0);" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s1343.photobucket.com/user/autoguy1/library/Honda%20Pilot%20Center%20Console" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" alt="autoguy1's Honda Pilot Center Console album on Photobucket" /></a></div>
