Same issue(s) here: 2017 Pilot Elite. Joined to follow this thread. I have brought it in 2 times before, but 3rd issue below just started happening and is really bad:
1. Pop of radio/electronics, beeping due to random error, error flashing briefly, car recovers
a. This will be Honda Ron Tonkin’s 3rd time looking at this
i. Previously reset some error code which did nothing
b. When: taking foot off break while in autostop.
i. Doesn’t seem to matter how long in autostop
ii. Not seeing any pattern of when this occurs
c. Types of errors – unrelated to what is actually happening
i. Break/collision
ii. Transmission
iii. Perhaps others
d. Frequency: Has been happening on and off in 2017
i. Can sometimes go a week without happening
ii. Can sometimes be in stop and go traffic and it happens along with #2
e. Priority: This is very annoying and slightly delays the car restarting, so could result in accident
f. Video of this available
2. Pop of radio/electronics, car doesn’t necessarily error but beeps, is suddenly in “Park” or “Neutral”
c. Problem situation: you are driving and on the freeway in stop and go traffic or at a red traffic light that turns green. Suddenly you are unable to drive forward, you can’t get out of Park/Neutral, even while pressing break. (panic ensues). People start honking at you and you are lucky if they don’t hit you assuming you will be moving. You must press the break and the power button to restart the car while on the freeway!
d. Frequency: This was the first problem I started seeing, it happens maybe slightly less than the #1.
e. Priority: Critical, this is going to get us killed!
f. Video of this available, of trying to get car restarted at traffic light.
3. Huge/loud pop of radio, car doesn’t beep, is still in Drive, but is dead
a. This will be Honda Ron Tonkin’s 1st time looking at this
b. When: stopped but not sure that autostart is on… both times this horrible one happened, it was a very brief press on the breaks (11/5: on freeway; 11/6: at stop sign). Screens on dash popped loudly, and suddenly engine was dead.
c. Situation: This was not a full autostop issue, so there wasn’t any expectation that it was going to restart, rather it was still in drive and the engine was going. Suddenly I am rolling backwards as engine is dead. I am still in drive, so I have to press the break to stop rolling into the car at the stop behind me! Then I try to put it in park or press drive again, that doesn’t work. I have to completely reboot the car by pressing break and pressing power button, then press drive. This is incredibly scary on the freeway because this was not as slow moving traffic as when the other situations happen (i.e. you are just pausing, not stopping long enough for autostop to do it’s thing).
d. Repercussions: seems that after the huge “pop” one of the screens under steering wheel is not working properly. There is a blank screen instead of the “home” one which normally shows things like your cruise control following distance/set rate. Also the buttons for collision and lane departure turned off and I had to turn them on manually.
e. Frequency: first happened Tuesday this week driving home from work, car had been parked all day, this was about 35 min into my commute., I called and made yet another appointment to have it looked at. Then it happened the next morning, was chilly, this time happened within four minutes of starting up.
f. Priority: I am extremely lucky I didn’t have a fender bender either time. This should never happen, you should be able to trust that your engine is going to stay running. This will also get us in an accident.
g. Video: none, happened twice.
