Spark Plugs
201K views 68 replies 32 participants last post by  ltp646
After 120,000 miles I figure it's time to chenge the plugs. Can someone provide the "degree of difficulty"? What needs to be removed and do I need to be a contortionist to get them all?
Plug recommendations appreciated also.
THANKS
2003 Pilot
#2 ·
On a scale of 1-10 (10 being "take it to someone who knows how") I'd call it a 4. You just need to remove the plastic engine cover, disconnect the individual ignition coils and remove them...then the spark plugs. You'll need a 10mm socket, 5mm hex socket/allen wrench, 5/8" spark plug socket, 3/8" drive ratchet along with the correct combination of extensions. The back 3 plugs are a little bit of a reach...but I'm not that tall, so I just grab a pillow and lay on the radiator support/hood while doing them so I'm not straining my back. Use the OEM plugs. Hope that helps. Good luck.:)
#5 ·
Changed Spark Plugs yesterday. Yes, the back three are a real bugger. I drove about 8 miles afterward with what seemed like no problems. Got in to go to work this morninga and it was very sluggish and the engine malfunction light came on. Drove a couple of miles and pulled over. I turned the engine off and restarted. The light went off and it was no longer sluggish. Hoping I didn't screw anything up. Any ideas what would cause this? Currently not in a position financially for a costly repair.:3:
#6 ·
What kind of plugs did you use? I would suggest rechecking the individual Coil-Over-Plug connectors. Maybe one was not clicked on all the way? Just double check everything was put back on correctly. If the light does come back on, I would take it somewhere just to see what the code is.
#8 ·
Got my plugs in this weekend and, knock on wood, everything seems to be OK so far. I actually had a harder time with the front center one - fan shroud is in the way - and figuring out which combination of socket extensions gave me the best clearance. Since the plugs cost about $9 a piece I hope these last 120K miles like the originals.
Thanks again for your advice!
#68 ·
2011 Honda Polit Touring 77K. The check engine light came yesterday, I brought it to the dealer they said it was the after market spark plugs I put in it "Champion plugs" they charged me $350.00, to replace them, the light is off for now. I changed the plugs B/C the light came on in the first place, if the light comes back on what should I do besides bring it back to the dealer any thoughts would be great.
#11 ·
$9 is a steal for an OEM Honda plug. The list price from Honda is $18.08 and the best I was able to find was $13.34 plus shipping. Can I ask where you found them?
#13 ·
I replaced mine with NGK Iridium, for no other reason other than, they were a little cheaper than the Laser Platinum which is the OEM plug - you can buy them both at Kragen Auto Parts (or whatever it's called in your area) I have noticed no engine running difference from before changing the plugs, except very slightly improved fuel economy, which I attribute to the old plugs.
Here's a link to the Laser Platinum http://www.partsamerica.com/ProductDetail.aspx?MfrCode=NGK&MfrPartNumber=4363&PartType=960&PTSet=A
#14 ·
It looks like the NGK double platinum plugs are sold at most parts stores but can anyone confirm that they are the same as the OEM Honda parts? I'd like to make sure I get the ones with the 105k service interval but can't find any reference to that other than from Honda.
#16 ·
I ended up getting my plugs from the dealer but probably should have hit Autozone and saved a few bucks.
It took a few hours but the new plugs are in. I've changed plugs multiple times in previous vehicles but this was my first attempt at getting into the engine compartment in the Pilot. Wow it was not what I thought. When I opened the hood my first thought was "where in the heck are the plugs?".
I knew the general vicinity to look in given it was a transverse V6 but it was amazing how much work it takes just to "uncover" them.
I actually found the front plugs harder to replace given the space limitations between the engine and the radiator. Even though I couldn't see the rear ones as well, there was more space to work with.
It would be nice to have a DIY for these things but without one the owner's manual gives some decent instructions for the first timer. I took some pics that I plan to post shortly as well.
I ended up using a 6 mm allen wrench and I think a greater assortment of socket extensions would be helpful.
Drove 500 miles today and averaged about 19 mpg but I'm not sure I'll be able to see any mileage improvement.
#20 ·
I'm by no means a master mechanic but I do some general maintenance and thought I'd post some pics that may be of use/interest to those thinking about taking on spark plug replacement.
Here are the covers I removed.
