A couple days ago I noticed that my instrument lights did not on when I turn on the headlights so I checked every fuse in the car, even those that I knew had nothing to do with the lights, and found a blown fuse in the passenger side fuse box. I replaced it and the lights turned right on but they were brighter than I usually have them so I tried to dim them down but they wouldn't dim. I took in the Pilot today to have them look at it and the service adviser told me that if the dimming system was connected to my aftermarket stereo and if that's what caused the problem, they would not fix it under warranty. I would have to pay $70 for them to look at it, if the aftermarket stereo was culprit so I told her that I would do my own research first and then bring it back in when I was more confident that it was not caused by the stereo. I would like to know if anything on the stereo harness connects to the instrument cluster lights. I know that the harness has a dimmer wire and an illuminator wire but the only one I'm using is the dimmer. I know the dimmer obviously dims the lights when the headlights are turned on and the illuminator will turn on certain lights when the headlights are turned on, but I just don't see why that would have anything to do with the instrument cluster's manual dimmer knob. Can somebody with the electrical manual tell me if there is a relationship between the two wires and the cluster? I can live with the lights being bright if my stereo caused the problem but if this is a Honda defect I'd like to know before shelling out the cash (and before the warranty expires,35950mi)
She also told me that my HondaCare warranty would cover this if it is not my stereos fault. Let's just hope she's right since I will probably hit 36K before going back in.
FYI: the illumination wire (not used) on the Crutchfield harness was cut and heavily taped during stereo installation so if that wire has something to do with the cluster lights, it's still not possible that I caused the problem. Stereo was in for a few months w/o a problem.
