I'm in the process of removing the Oil Pan and have found what I believe is the crank sensor attached to the oil pan. I've removed the metal guard/cover and the single bolt attached to the sensor. However, I am unable to remove the sensor. Does anyone know the "trick" to removing without damage to the sensor, bracket, cable or oil pan?
