Android Issues
2.1K views 5 replies 5 participants last post by  IntrusDave
The other day our Pilot's Nav/Ent system made a weird beeping sound and this screen popped up. It's looks to be a diagnostic screen of some sort. I had to restart the vehicle to get the screen to go away. While the screen was up the radio continued to work and Pilot drove normally.
And today I was trying to make a Bluetooth call and an Android error popped up as well, but everything continued to work.
Anyone else experience this?
#6 ·
Given that you said it drives normally, I assume that means that you were driving at the time.
That said, it is showing CAN BUS errors (Assuming the car was running). Do you have some type of device plugged into the ODB-II port under the dash? Many of these data loggers - the come from Verizon, Progressive, and many other 3rd parties - use the CAN BUS to pull info about what you are doing and where you are. If you have one plugged in, I would remove it.
