Air keeps getting into my power steering system new rack , pump and high pressure line don't see any leaks any where. I purge it several times works for a few minutes then start making noise again what else to be done.
+1 on the plan of attack and definitely OEM O-rings! For a few bucks they may be one of the least expensive parts from the dealer.pump replacement should be last ditch option. o-rings first, reservoir replacement second or at same time as a fluid flush. can order everything at the dealer or online. dorman even makes the o-ring kit but I would go honda
Are you using Canadian bucks?For a few bucks they may be one of the least expensive parts from the dealer.
Shipping from .com or IIRC picking them up from the local dealership will push them into the few bucks levelAre you using Canadian bucks?![]()
I’m not sure what model the diagram link you posted refers to, but as you can see above, it doesn’t break down the PS pump. So maybe that’s why the culprit o-ring isn’t shown in this diagram.looking at this I am not seeing a return line o-ring on the pump, only a pressure side o-ring
https://www.hondapartsnow.com/resou...com/resources/encry/diagram/hpn/2021/large/f34d821f4ce2ae894b779985aea93c9a.png
I'm pretty sure only the 1st gen Pilots PS pump had the inlet & outlet pump o-rings.
this milkshake looking fluid. Maybe that’s all air bubbles,
Get the new orange-flavored o-ring.
Hi pressure side would squirt out fluid, not suck in air. Don’t you think the same?Just to pile on to existing advice: frothy, milkshakey, air bubbly PS fluid is evidence of air entering the system. The most likely culprit is the high-pressure side O-ring. Start by replacing the fluid, the O-rings, and making sure you have the right fluid level.
--Chris N.
I replaced my o-ring tonight and the noise is totally gone now. Thank you! The video in post 5 is excellent!Mine would only make noise when cold outside. I replaced the oring and that solved the issue.
There are 2 o rings, did you replace both to rule that out?Hopefully I’m not too late to the conversation, but I’ve been foghting air in my system for weeks. 07 pilot, replaced pump, new reservoir, new hose from pump to reservoir, and new o rings. Had turned the wheel from lock to lock at least 100 times and there is still air in the system. Seems like it’s getting worse. Should I replace the high pressure hose? There wasn’t any fluid leaking that I know of before I started replacing parts.
OEM Pump, and Fluid?Hopefully I’m not too late to the conversation, but I’ve been foghting air in my system for weeks. 07 pilot, replaced pump, new reservoir, new hose from pump to reservoir, and new o rings. Had turned the wheel from lock to lock at least 100 times and there is still air in the system. Seems like it’s getting worse. Should I replace the high pressure hose? There wasn’t any fluid leaking that I know of before I started replacing parts.
