See the title. Dealership quoted me at $1889 to replace the AC compressor due to my Pilot blowing hot air while idling. Is this a reasonable price or am I being ripped off? I thought this was a less than $1000 repair?
I'm not quite certain what's going on here. The thread title says you were quoted an AC compressor, but this sentence states you need a condenser (which is the radiator-like component that sits just behind the grille). You mentioned they installed leak dye -- did they observe that leaking anywhere? If they found it leaking from the condenser, and nowhere else, then you may be able to get away with simply replacing that. There are no moving parts in the condenser and there's little chance that this failure, by itself, introduced debris in the system to justify replacement of other components....I brought it in today asking them to take another look to find if the UV dye they put in leaked in the hose anywhere and they came back saying it's the condenser that needs replaced...
