Our 2016 Pilot with 9 speed tranny has about 35K miles on it. No issues.
Dealer has recommended we do a drain/refill on the transmission fluid. This is a simple drain/refill, not some flush or other nonsense.
Trusted mechanic friend says periodic drain/refill is the way to maintain your automatic transmission.
Dealer is quoting $500 to perform this service. I would expect something like this to cost about $50.
Wife and I both looked in provided documentation and on line and could find no factory recommended service interval. Very strange.
Dealer said the factory recommended interval is 90K miles, but the 90K mile service is a more involved procedure to extract most of the oil from the transmission/torque converter. Dealer says instead of the more involved 90K service, do a drain/refill every 30K miles.
Dealer provided detailed invoice for $500 transmission oil drain/refill.
-Three drain plugs $103.68
-4 qts ATF $219.32
-2 hours labor $128.80
-Shop supplies $25.76
-Tax $24.58
$502.14
I've worked on a few cars in the past and have never replaced an oil drain plug. Sometimes there is a nylon washer that might need replacing, but never the entire plug. Why are they replacing the drain plugs?
If I Google the part numbers for the fluid and plugs I can find what appear to be Honda factory components for about 1/2 price.
2 hours labor seems a bit much. I did look under the Pilot and noticed various cover that might have to be removed for access. 2 hours still seems high.
$25.76 for "shop supplies". Ya right. it should read "$25.76 extra dealer profit".
This is not the first instance of rather expensive preventative maintenance from this dealer. Of course if you service the car exclusively at the dealer they "give" you an extra year of warranty. And "free" car washes.
Due to the advice from trusted mechanic friend, I am inclined to do a drain an refill on the transmission. Any advice on how to get it done for a reasonable price?
Big
-4 qts ATF $219.32
-Tax $24.58
$502.14
Big
