After searching you tube for an example of how to replace the right rear axle, only found one that covered the subject.
From my understanding, the steps are
1 loosen hub nut
2 remove tire
3 remove shock absorber
4 remove four botls from hub/ trailing arm or two bolts that hold the trailing
arm to the sub-frame
5 remove bolt from upper control arm
6 remove nut from axle
7 rotate hub assembly to remove axle from hub assembly
8 pop axle out of rear differential case
9 insert new axle into rear differential and pop into place
10 repeat steps 7 to 1 in reverse order.
Any advice would be appreciate. Thank you
1 loosen hub nut
2 remove tire
