<a herf="https://www.xenondepot.com/hid-kits-and-lighting-by-vehicle-s/2000.htm"/><img src="http://artoflightindustries.com/xd/images/design/forum/xd-forum-fall-18-main.jpg"</img></a>
<a herf="https://www.xenondepot.com/H11-Xtreme-LED-kit-pro-p/xt-led-h11-pro.htm"/><img src="http://artoflightindustries.com/xd/images/design/forum/xd-forum-fall-18-h11ledupdate.jpg"</img></a>
<a herf="https://www.xenondepot.com/921-T16-Xtreme-LED-bulb-p/xt-led-921c.htm"/><img src="http://artoflightindustries.com/xd/images/design/forum/xd-forum-fall-18-921led.jpg"</img></a>
<a herf="https://www.xenondepot.com/Promotional-Sale-Details-s/13.htm"/><img src="http://artoflightindustries.com/xd/images/design/forum/xd-forum-fall-18-promo.jpg"</img></a>
Check out XenonDepot.com for great deals on all your Tacoma lighting needs!
Discussion Starter #2 (Edited)
Take a look at new Xtreme LED 921 Bulbs in action which was tested in a Toyota 4runner and compared to a traditional style ''Tower" style LED bulb.
<img src="http://artoflightindustries.com/xd/images/vehicles/4runner-reverselights/xt-921-4runner-img-1.jpg"</img>
<img src="http://artoflightindustries.com/xd/images/vehicles/4runner-reverselights/xt-921-4runner-img-4.jpg"</img>
Danny
Discussion Starter #3
It's been a busy week here at XenonDepot.com and we've just had some fantastic new lighting options arrive:
<img src=http://artoflightindustries.com/xd/images/design/forum/xtpro-drl-led-driver.JPG>
The Xtreme PRO DRL LED Driver - this replaces the regular LED Driver found in our Xtreme Pro 9005 LED Kit, and will allow the LED bulbs to dim down in Daytime Running Light (DRL) mode, while still getting full power as a High Beam. Finally the wait is over! You CAN have a 'True' High Beam/DRL option with an LED Kit - no more flickering or DRLs that are just like running your High Beams during daylight hours.
Already have one of our 9005 LED Kits with the PWM Module option installed and want to upgrade? All you need to do is remove the existing LED Driver and PWM Module, then attach the new DRL Driver to the bulb instead. It's that simple!
The DRL Drivers were designed and tested based on a 5th Generation Toyota 4Runner, but many other vehicles use a similar PWM power signature with the High Beams and DRLs sharing the same bulb. We are working to compile a list of compatible vehicles, and would appreciate any and all feedback you can provide.
<img src=http://artoflightindustries.com/xd/images/design/forum/xtremeledpro-yellow.jpg>
Want a bright yellow LED solution for your dim Fog Lights? Look no further - we have developed a version of our Xtreme PRO H11 LED Kit with a bright Yellow/Amber colour (2700K) that you can use! Rated at ~1150 stable lumens (after running for about an hour), these make a great upgrade for H8, H11, and H16 Fog Light applications.
Using the same great design as our Xtreme PRO H11 LED Kits in White (5500K), the Xtreme PRO Yellow H11 LED Kit has its emitters positioned to match the filament from the OEM halogen bulbs, and is also using the upgraded solid heat sink fins found on our regular H11 LED bulbs - now with better heat dissipation.
~Robert
Discussion Starter #4
Discussion Starter #5
Happy Friday everybody!
Check out this great video showing off our H11 HID Kit, as well as the Xtreme PRO 9005 LED Kit with the Xtreme PRO DRL LED Drivers, all in a newer 4Runner.
You can really see the difference with the DRL Drivers installed - you get to keep your stock functionality, with DRLs that dim down to a more appropriate level of brightness, while still getting a nice boost in output when they get that full power signal in High Beam Mode.
<img src=http://artoflightindustries.com/xd/images/design/forum/fb-video-drl-led-driver.png>
Discussion Starter #6
