61 - 73 of 73 Posts
My hangup there (as it was with using the non OEM filter) is that transmissions can be so sensitive to pressure provided and how does this system change that pressure. Is it enough to affect the behavior of the transmission? Cause issues that will cause long term damage? I understand the desire to filter the transmission to get the most life out of it but it's not quite as simple as throwing a kit on IMO.
Discussion Starter #63
The filtration and cooling system of the transmission has little to no bearing on the mechanical operation of the transmission itself. That is, until they fail (leak, plugged or over heat).
I had similar reservations of adding or using aftermarket trans filters when this thread popped up. I don't know what psi the transmission pump generates, requires or whether a particular filter has too much resistance to flow and are there bypass valves. I like that kit posted by @Nail Grease post #63 as that kit has all the features a trans fanatic needs.
Discussion Starter #65
Install with confidence. No need to worry. Only thing I would do is pre-fill the filter.
Yea I'd need to know more about how the pump system in this transmission operates and more information about flow through the filter/whether it has a bypass, etc. If the transmission pump picks up from the "fluid pan" and after the fluid runs through the transmission it is pushed to the cooler than the filter than the pan again, this would likely have little effect on operation. If the pump pushes fluid through the cooler and the filter first I have more reservations about using it.
Something else I am just thinking, the filter for the 3rd gen 6 speeds just goes in the middle of the return hose. This filter could probably be used on 1st and 2nd gens with the cooler as well...
Discussion Starter #67
I would actually just buy the filter base alone because our hoses and conectors need to be the proper diameter to fit the in and out ports.
If the diameters are close that should clamp okay otherwise some hose adapters should work. But once the connections are made that spin on filter is neat.
It would be as easy as changing the fuel filter on my '64 Plymouth Valiant when I was 16 years old. :)
Discussion Starter #70
I think I still want to try to get the right hose size and connections.
This filter base has the in and out ports on the side.This configuration would be better than out the top like the other one has.
135185
Does the factory filter have a bypass in the end metal cap like others complained the BeckArnley doesn't?
I forgot which forums but they also showed that the new Magnefine filters fit into factory clamp on the Honda's. Bigger filter area and the magnet for capturing the fine stuff.
2004 Pilot EX-L
I bought a Wix ATF filter for my 04 Pilot. Was planning on replacing the original filter (180k miles) next time I do a drain and fill, probably in a few weeks. Should I chuck the Wix filter and get a genuine Honda filter instead?
Discussion Starter #73 (Edited)
Depends who makes the part for Beck/Arnley.
What you wouldn't want is something like this one:
There is no bypass valve in a Honda factory ATF filter as some say or video claims.
The pleats are glued in just like the one in the video.
135450
135451
61 - 73 of 73 Posts
