1 - 1 of 1 Posts
I want to add a line converter then to the amp and from the amp back to the speakers.
Do I cut the radio harness in half and use the top part that connects to the radio plug as input wires to the line converter then the output wires from the amp to the lower half of the harness I cut?
I feel that would be wrong as the bottom part of the harness will go through the factory amp muddying out the gains from the aftermarket amp.
Do I have this right or how do I wire the output wires from the aftermarket amp to the speakers?
thanks.
1 - 1 of 1 Posts
