1 - 13 of 13 Posts
So recently the passenger rear window on my 2004 Honda Pilot stopped rolling up. It will go down but it will not roll up. So I replaced the motor and guide. I am still having the issue. So my question is where do I find new switches for the windows? And do I replace the driver all control ? Or just the passenger rear that is having the issue. I can roll it down with both of them but it will not roll up. Please help!
Bad? who's Bad? Where's that MJ video again?
J/K- hope you solve it
If both switches stopped working around the same time I’d suspect wiring either within the door panel or the rubber boot between the rear door and chassis.
Reactions: plplplpl
It has always had a slight delay when rolling up that window since I have had my pilot but the other day it rolled Down and wouldn’t go back up. So I bought a new regulator and when I plugged it in once again it will go down but not up
When did the driver switch stop raising the rear passenger window?
When did the rear passenger switch stop raising the rear passenger window?
If the answer to those two questions is the same day, then my bet is that both switches are good.
You can prove/disprove this if you have a multimeter.
Discussion Starter · #12 ·
Thanks for the info. I’m going to check as soon as I get off work. They stopped at the same time.
1 - 13 of 13 Posts
