2017 Pilot Touring. It has 20" wheels. I think these are 8JJx20 ET55 (from wheel size) website.
I am looking to get another set for winter tires. Will the following fit this Pilot?
245/65R17 tire , 7.5Jx17 ET45 rim
245/60R18 tire , 7.5Jx18 ET45 rim
These have same bolt pattern as the Pilot: 5x120. Center both for all the above is also the same: 64.1mm.
Basically, with the 7.5 width fit the 8 width of the pilot? Also, is the offset of 45 compatible with 55 offset on the Pilot?
Thanks!
The rims you are looking at have a 10mm (0.4”) more negative offset compared to stock. This means if the rim was 8” wide it would stick out 0.4” more toward the street.
But since the rims you are looking at are 7.5” wide this means that each side protrudes 0.25” less compares to 8” rims of the same offset. I believe net effect is new rims stick out towards street 0.15” more than stock. On the axle side the tire will protrude 0.35” less toward axle. Check one of the offset calculator sites to confirm.
