Also helpful if someone can give instructions on how to flush the coolant for the 2019 pilot.
No offense, I'm going to get lamblasted for this one, but,
Why on earth would you flush coolant on a 2019?
Reactions: aggrex
2020 Pilot Black Edition
They are all pretty much the same. How to Maintain and Flush a Cooling System So Your Car Doesn’t Overheat
You have to remove the right front wheel to get to the block drain plug. It will look like an oversized zerk. A hose to fit on the nipple is a nice addition to drain the coolant.
This is the view from a 2017 Ridgeline.
[/QUOTE
This is the view from a 2017 Ridgeline View attachment 140680
(in addition to draining the petcock valve below the radiator)
:LOL::LOL: Just being proactive, and curious. Since I just DIY from YouTube videos on my 2013.
Not doing it on the 2019 yet, but can’t find a video on how to do it for 2016-2019.
Hey check out the attachment for the coolant replacement procedure, right from Honda. This is specifically for the 3rd Gens, but likely is similar for previous generations.
Here is a post with a link to the Honda factory service manual for the 2016 Pilot. Most information will be the same for the 2019 Pilot or the 3rd generation Pilots.
2016 Service Manual
Reactions: zmarke01
