1 - 20 of 186 Posts
I was just reading this thread about the 3rd gen about no place good to hook up a towrope, and someone mentions there's a towing eye included in the 2nd gen, and that got me wondering about the 1st gen.
If you have to hook a towrope (not to tow but to get unstuck or help pull someone out), where do you hook it up to in front on a 1st gen?
I've got a tow hitch in back, so there's always that, but what about in front? I must admit I haven't ever needed that with the Pilot, so I haven't looked closely, but just in case someday I do, either to get pulled out facing forward, or to help someone, where do you hook up a towrope on the front?
Owner's Manual only says don't use the bumper, lol.
Tie-down loop in the middle for me. It's a fine jack point, so I wouldn't hesitate to use it for light tow duty. No yanking out tree stumps with that one, though.
Oh good, interesting. It's -16 C out today so do you have a picture so I don't have to go out and look? I can't find one on the internet. :( I know, I know, they revoke Canadian passports for such wussiness.
Following!
What? I just assumed all Canadians went ice fishing and had no problem with cold temps. These folks seem to enjoy the weather.
Man I hate to see you break tradition. :p
Not my Pilot but the first gen has this welded loop on the front subframe but I don’t think it’s considered a recovery point.
Automotive tire Light Automotive fuel system Motor vehicle Automotive exhaust
THAT, is an awesome video!!
Reactions: Nail Grease
Not my Pilot but the first gen has this welded loop on the front subframe but I don’t think it’s considered a recovery point. View attachment 145333
I don't think My 1st gen has this? Or my 2nd Gen? That looks aftermarket to me? As does that pan under the motor?
Reactions: plplplpl
When I took out the PCV to change it, that little metal spacer fell down into the great abyss. It's non-magnetic so a magnet pickerupper won't help, so after wasting 10 minutes looking for it, I yanked the whole bottom vanity panel off and out it came along with a number of other lost items, tools, parts, and things I didn't even recognize. Under that vanity panel is hiding this hungmunga. Not aftermarket. This is a 2nd gen Pilot. I can see a lot of jobs that will be a lot easier without this panel in the way. Good time to add an external transmission filter. The lines are right there within easy reach.
The panel is huge, you uncover a lot of access by removing it. I'm not sure I'll ever put
it back.
145337
it back.
Did you find thise needlw nose pliers in there I lost a while back? LOL
Thanks, good to know, I'll take a look under there soon, on both my Gen 1 and Gen 2.
Reactions: plplplpl
That Pilot owner used an F250 gas tank skid to make a skid plate for his Pilot. The welded loop on the subframe is his “recovery” point.
That's a metal shackle. I'm guessing the tab on the frame is OEM. Similar, usually smaller 1/4" bolt are used extensivly in sailing- they are stainless too.
You can get a metal one like that at about nay hardware store me thninks.
Discussion Starter · #16 ·
I can hear some old man grunting sounds in that video, but they were still more restrained than mine when I took one for the team by kneeling and squatting to take these pictures on a -10 C icy, salty surface today.
145346
145345
There's a hole in that metal piece jutting down from the frame. Not sure if it's quite big enough to put a towrope hook in. Too cold to try. Maybe I'll ask those ice fishermen guys. Or someone in a warmer clime?
Discussion Starter · #19 ·
Ooh, then I want a shackle like that to hook up. My plastic beauty cover skid plates :D obstruct access to the tube. It'll be like giving my Pilot a nose ring like all the cool kids about to drop out have. :)
Dimensions? Links?
Warmly appreciated.
145371
Dimensions? Links?
Warmly appreciated. View attachment 145371
Here's one link.
I'm looking thru my old sailing tackle, and also checking my local ACE store!
Won't this mess with the front lower cowl when using a rope/ chain to pull it from there though?
1 - 20 of 186 Posts
