2016 Honda Pilot Touring (Canada)
Do you need to use a Load equalizer for every halogen lights you change to LED? Thanks!
Super Moderator
Not sure what you mean by a load equalizer but you do need to use the proper resistor for your turn signals to prevent hyper flashing. This might help:
Some bulbs come with built in resistors, however if you purchase this type you need to spend the money for good quality bulbs. Often the cheap Chinese bulbs either don't work or burn out quickly.
Not sure what you mean by a load equalizer but you do need to use the proper resister for your turn signals to prevent hyper flashing. This might help:
Thank you! I’m actually looking at changing the reverse light. On the sylvania website it says something about a load equalizer. See photo. That’s what I meant.
Is that only needed for turn signals?
138844
Super Moderator
In this part of the world they are called resistors.
Super Moderator
Oh! Gotcha. Thanks for clarifying that. So is that only needed for turn signals and not the other lights?
Yep, they are to prevent hyper flash. The lower voltage signals the computer that the blinker voltage is too low, thus causing the hyper flash to tell you that you have a burnt out bulb.
Awesome! Thanks for sharing your knowledge.You’ve been very helpful.
