We have a broken lug stud on the Pilot (2005). After taking the tire and rotor off, it would seem it would take a press to separate the hub from the steering knuckle. Given that this is the case, I am leaning toward replacing the entire assembly rather than pressing out the hub and redoing the wheel bearings. It's either that or find someone with a press and paying them to replace the stud and potentially the wheel bearing if it ends up being necessary.
I was looking at Rock Auto at hub/knuckle assemblies. I see Dorman, SKP, WJB, and Ultra Power. Are any of those any good, or am I better off going with Honda?
If Honda is my only real option, the expense of labor on having someone separate it and replace the wheel bearing along with the lug stud wouldn't be so bad. If I go with the separation option, is there something I am missing in the process? I don't see 4 bolts in the back like other models I have seen videos on, so I'm not sure using a slide hammer to separate them on the car is a possibility. I am assuming since is appears to be pressed together it, will take a press to separate them. Is it possible to separate using a slide hammer and then a way to get it back together without a press?
Sorry for all the questions, I am just trying to figure out my options.
