The sounds my car is making now seems to indicate that I'll be due for at least one new wheel bearing hub assembly and likely new front struts. I heard someone say that for wheel bearing hubs, you should try to use the Honda ones. If I can save some $ by buying Timken, Moog, or another brand who makes the Honda hub units. Do any of you know who happens to make the Honda wheel hub assembly?
I'd like to know the same. I'm pretty sure both my fronts need replaced as well. I'm confident in my ability to do the job myself, but I wouldn't mind saving some money in the process. But I also don't want to cause an issue and find myself doing the same job within a couple of months.
From another thread I read, OEM is Koyo.
I'd have no problem installing SKF or Timkin from RockAuto. The price difference is to great.
...and I would stay away from WJB.
