What tire Pressure do you use on your Pilot?
  • 32
    Votes: 22 56.4%
  • 33
    Votes: 2 5.1%
  • 34
    Votes: 6 15.4%
  • 35
    Votes: 3 7.7%
  • 36
    Votes: 4 10.3%
  • more
    Votes: 2 5.1%
1 - 10 of 10 Posts
The pilot sticker calls for 32PSI. However the tires are rated for a max. of much more.
On other vehicles, I have found that my tires wear better a bit over-inflated.
On a Toyota Previa, (Calls for 35PSI) , the tires were rated for 44 max and I generally inflated to 39 or 40 cold. Wear over 40K miles was fine, and was even across the tread. Same idea on a Toyota Camry which calls for 30, but I inflate to 35 (the tire max rating). 36k miles so far and wear is even. This makes the ride a bit firmer- which I don't mind, and I do not get uneven wear that would indicate over or under inflation.
What pressure do you use on your Pilot Stock tires? Other brands?:2: :2:
Premium Member
I run 36-38 in mine. Provides less rolling resistance (better MPG) without any significant degradation in ride quality.
YMMV
I find anything above 32 gives too firm a ride. Still on the Goodyears, budgeting for Cross-terrains.
After reading a few posts about tire pressure in here, I decide to inflate my tires a bit higher than the specified number of 32 when cold. I really haven't noticed too much of a difference in the ride, so, I'll stick with 34.
35 AW:)
Discussion Starter #9
Tire Pressure
Based on the Poll, the overwhelming majority of us are using the stock 32 PSI. I am using 37 and plan for now to stay there.
Thanks to all who replied and voted on the poll.
max -10%
On all cars I've owned, I always run the max pressure the tire is rated for minus about 10%. If the ride is way too firm I may adjust, but I prefer a firmer ride anyway, and tires run cooler and last longer with the extra air.
1 - 10 of 10 Posts
