101 - 120 of 166 Posts
I guess practice make perfect. Here the hood wrapped in ppf. Tried my best by myself and kinda failed. 60”x7’ was hard to lay down by one person. At least I have enough to learn and make few mistakes on. Will redo once I get few more thing this time with a friends help.
137134
First doing a two step paint correction.
137135
laid down the ppf as you can see some air bubbles in it.
137136
edge wrapped and tucked.
137137
As you can see I had a few finger on the edge from not able to stretch it good.
I did my quarter hood by with my son holding it so I can stretch it and it was difficult. No way I wouldve tried the whole hood alone. Alcohol solution right before the hood curves down helped it stick in place better. get another person to help with stretching. blast under those fingers with the alcohol mix and hold it and they should stay down. I had one i hit with alcohol then put a microfiber towel on it and clamped it with a spring clamp. it finally stayed down. keep us updated
Finally redid the hood it better but not perfect. Still have few air bubbles in it with water. So I’m have to get syringe to suck it out. But other than that it works for me. Protecting the paint from any more chip Is the main goal. Here few pics.
137186
137187
137188
137189
Didn't work that hard on the new Passport as it is already coated, but I did manage to get a boat load of music downloaded to My Honda Music. I love this system so much better than the cd/hard drive combo in the 2013 Pilot. Easy to download, easy to delete, songs or albums and reads all the metadata so much better than the Pilot did.
I used a pin and pushed the air/solution out with a microfiber towel which soaked it up. U are a glutten for punishment
Syringe worked out perfect sucked out the solution and sun dried to warm it up. Looks better now. One mistake I made was using 32 ounce slip on a full hood. I need at least a gallon to really keep it from sticky quick. Next be the bumper and fenders.
137212
137213
Looks good. Did you consider opening the driver side door to tuck in the fender easier?
I went the cheap route today and put on some temporary stuff for my trip down the East coast.
Never heard of that stuff I’ve seen the 3M spray one. Yeah I it has to be open to tuck the edge for sure. Good luck on your trip any protection better than none.
*This is for a 1st Gen Pilot - 2008
Bought some used-rims, intent to be used for FULL-SIZE SPARE,
they weren't in "terrible" condition, but, for a can of $6 Rust-oleum Primer/Paint, some 80grit and 400grit sand paper, and some time and elbow grease, decided to make them look a lil bit "better" .
Before pictures below.
AFTER pictures (garage wall color reflected in picture to give the goldish color)
This below pic shows closer to actual color after drying (grayish/silverish)
Paint Used
Rustoleum spray can
Rust-oleum spray can
Drove it and the timing belt didn't fail! Never been replaced since 2003 and 61k total miles. The pilot is the wife's car so, she thinks since it's a Honda it "will never break down". I've told her about timing belt replacement at 105k or 7 years (whichever comes first) and when it goes and destroys the engine, it's all on her to figure things out.
View attachment 137623 View attachment 137624
View attachment 137626 View attachment 137625 View attachment 137627
Paint Used
Rustoleum spray can
But now you have to crawl under the back of your PIlot several times a week to admire your excellent work result. :D
Installed the trail hitch today... only planning on hauling the bike rack.
Easy installation but would have been nice to have had a set of extra hands. Had to set it up on jack stands to assist and get it close enough haha.
