1 - 20 of 367 Posts
· Registered
Traded Pilot for Highlander
I couldn't find a thread like this, so if there is already a thread please delete or merge.
Today I changed the rear differential fluid for the first time and changed the engine oil and filter for the second time. Current mileage is 13,028 and the vehicle has been great. Both jobs were pretty easy, though I am not a fan of the oil filter location. I used a little over 2 quarts of Honda Dual Pump II for the diff and 5 quarts of Castrol Magnatec with .7 quarts of Valvoline FS that I had left over from my CRV oil change (both 0W20) with a Fram TG7317 filter.
· Registered
2019 Pilot Elite
The rear diff, did you slide underneath or jack it up?
I need to do mine this week.
TIA
HSB
· Registered
2019 Pilot Elite
I slid underneath, however, jacking it up would have been more comfortable.
Thank you. I'll give it a shot tomorrow.
Last time I did the oil change I didn't jack it up and it was a tight
I did however turn the steering wheel all the way to the right and was able to access the oil filter much easier. The location sucks but i was even able to get my vice grip pliers in there so I didn't have to curse and scream at whatever Honda tech over tightened the oil filter.
HSB
· Registered
I am thinking of Striping my Pilot with either Back, Red or Gold stripes. White exterior and black interior
Have any of you done it? What colors did you choose?
I haven’t done anything like that but I think red would look good on your white Pilot in your profile picture.
· Registered
2019 Pilot Elite
Have you looked at the decals available from Honda?
Only problem is if you keep the stripes or decals on for a long while the paint will slightly fade but not under the decals.
And then also when you remove depending on how much wax or whatever you have the layers might not match.
Im not a specialist... but I remember my brother taking pain striping off and it was a noticeable "lip"?
Also not sure if you care.
For me, I prefer to blend in and not have any distinct marks on my car but then again I sometimes drive like a prick. My preference is always fly under the radar ??‍♂
HSB
· Super Moderator
Got the Pilot up on auto ramps for some visual inspections looking for any issues before they become big problems. With what I found it’s a bit amazing the Pilot is starting + running great and I want to keep it that way.
· Registered
Discussion Starter · #19 ·
Corrosion got the best of that ground wire. I assume you live somewhere up north? What's the plan for that?
· Registered
Our Pilot has barely moved in the last month. But after I get the lights installed in the garage I plan on washing the Pilot and Traverse and giving them a maintenance coat of spray wax.
1 - 20 of 367 Posts
