1121 - 1140 of 1293 Posts
2006 Honda Pilot EX-L - - 226k 2007 Honda Accord SE - - 145k
Or, risk the consequences.
The Gs on that acceleration look like how I feel when on my Pilot VTEC kicks in yo.
1. New AC Clutch Relay- Autozone- Santech MT0610. 16$ + tax- got the last one.
So you're the guy. I wanted that one as a backup. :D
2. VTM-4 fluid Exchange using new HF pump. My 1st go but been done every 30k or less. Had to hold hose in Fill hole with left hand, legs holding pump, right hand pumping. (You know you are good when you can swap hands and gain a stroke 😉)
Please tell us you got a vid or at least pics of that. If not, you know you can't have too many security cameras nowadays. :)
Wish me luck, it finally cooled off enough to try to get that %$&# bolt out. Now if only the rain holds off.:rolleyes:
Well If you don't count breaking, or dislocating a finger, and the sun deciding to return with a vengeance.....
I posted photos on my 06 LX topic.
Yeah, I either broke or dislocated the middle knuckle on my left index finger. Was getting hot & sweaty and forgot to unplug the drill when I extended the StubbyBit a little to reach a bit deeper. Accidently hit the trigger and bent the finger about 45° at the middle knuckle over the middle finger with the chuck key. Once I could get a bite with the broken bolt extractor it unscrewed by hand, didn't even need to put a wrench on it.
Finger's pretty stiff, swelled, and sore, but that #$%& bolt is out. (y)
The worst part was hearing the doctor, some M.D, go "ugh" when she saw it. Uhh, some bearing please?
But yes, screw the Pilot for now, time to take care of Cousin Itt's possibly broken finger.
So here was my mishap -
151106
C'mon, ya buncha whiners. When that happened to me, it just buffed right out. :p
Use the force, @mschflbn :).
2006 Pilot LX 4WD
Who's whining, when it happened I looked at it and pulled it forward and then sideways and went back at it.
I'm not spending $400.00 just to have them tell me it's broke or whatever. I need to use the money to fix the Pilot.
How's that for priorities?
Oh come on! You could go in and when they ask what is wrong, just say, "I think I have diabetic covid-COPD ulcerative mesothelioma in my index finger."
Okay, bad joke. But here IS a good one -
So I used to go to this "cut rate" doctor office. The doc, some younger woman who looks down her nose at people, said I had type 2 diabetes. At a later visit, for an ear infection, she was asking if there have been any changes in my feet (my feet are JUST fine) and I said, "Well, no but should we go ahead and schedule an amputation anyways?"
The look on her face could have been a viral meme.
2006 Pilot LX 4WD
Since the weather decided to be nice, made a boneyard run by @The Todd to Franklin and got the parts to replace the damaged timing cover, motor mount bracket, and a few other small parts out of an 07 Ridgeline that I missed seeing on previous visits. Hard to tell what it was with everything that was already gone.
So I'm $ 31.65 lighter but I've got all the parts I'll need to do the air pressure test. (y)
Premium Member
2005 Pilot EXL- 227,700 Miles
Went back to discount tire to pick up an “OEM” (steel) rim so I can have a full size spare that is plug and play- ie... use standard lug wrench and nuts.
Advance Auto run for Prestone Concentrated & Peak Coolant Tester
I sold it. Now on the hunt for another one I can resurrect like the last one. Or an MDX. Either way.
Too bad you can't double-icon like a post. I'd put in a sad smiley then a thumbs up.
What color?
151253
Pilot hard at work….. View attachment 151252
Seems to me those rear shocks are a little saggy. Prolly not KYB. :)
Premium Member
Maaaaannnnn....that’s BadA$$!!
Did you have to go back with 2- gals of coolant or doing the job only drain 1/2?
I put in $102 worth of gas, FWIW.
Of course, that's in Canadian patacas (look it up; I once won 2 at a casino but then lost them again), so that's about 3 dollars and change US :D.
Premium Member
Got the boneyard TB parts installed so I can do the cylinder leak down test. (Air Pressure Test)
Turned motor over 3 revolutions by hand, found no obstructions.
Will have to do leak down test tomorrow my finger's not happy, and my brother has the torx bits.
YESS!!! Looking good so far 👍👍
BTW....... could it be your twin brother?? Lol
