2401 - 2420 of 2446 Posts
· Registered
2006 Honda Pilot EX-L - - 248k 2007 Honda Accord SE - - 156k
What year is your Pilot? I've got an 04 and when I removed my spool valve assembly, the original gasket had the screen on it, so I replaced it with the same.
Mines an 07. I don't know if they had different ones for different first gens or what. The parts guy at Honda was confused too.
· Registered
2004 Pilot EX-L
Very pretty. Where'd you get it from and how spendy?
Online from a transmission shop with rebuilt old stock for around $1200 shipped. It was their last one. I'm thinking of cleaning up my old one and rebuilding it myself as an educational practice, then I'll have a spare in case this new one dies.
· Registered
I replaced the middle panel assembly on the dash. Item 28 below.
An errant box from the back knocked out a bunch of the vent louvers in the center of the panel when we were moving.
No more gap toothed grin to torment me....
Looks complex, but only took about 30 minutes.
I need to perform exactly the same part replacement (middle panel on 2005 Pilot-EXL) for similar reasons.
It's easy to find the replacement part, but I'm not finding any written or video instructions describing how to remove and replace the component safely.
Do you know of any? Otherwise, any tips on how you did the job?
Thanks, jjo
· Registered
· Registered
2004 Pilot EX-L
Now that I've got my Pilot running with it's new transmission for the past few days, everything seemed to be fine except that I was getting a really loud electrical whine noise in the cabin that was directly related to the position of the accelerator pedal. I've got a battery voltage meter in the 12v accessory socket in the center console and could see that the voltage was really sagging with the headlights on and under any light loads. The engine still had the original 04 alternator on it, so I replaced it today with a reman Denso unit, and the noise is gone and the output voltage is stable and strong.
· Registered
2004 Pilot EX-L
Followup, turns out the new alternator might not be working quite right. It puts out 14.6v right after starting up and for the first 10 minutes or so when driving on a highway with constant accelerator applied, but then if I take my foot off the gas and let the car coast, it drops to 12.1v and stays there until I either come to a stop, or hit the gas again. Is that correct? I didn't get any warning lights on the dash, but it seems wild that there would be a 2.5v voltage swing based on whether I'm hitting the throttle or not.
· Super Moderator
In the interim the local auto parts store (advance/autozone) could test the alternator performance in the vehicle. Sometimes the rebuilt alternators can be hit or miss. When I ordered my new Denso alternator online from hondaautomotiveparts the rebuilt Denso had a longer warranty than the new Denso.
· Registered
Whine matching RPMs is a classic alternator symptom. Reman Denso is usually a good option, but the variable is who did the reman?
Next step I'd try is to vary that variable. :)
· Registered
2004 Pilot EX-L
I got the reman Denso from RockAuto. I'm heading to my favorite junkyard tomorrow to pull an alternator if they've got a good one. Their website says they got 5 new 03-04 Pilots since I was last there 2 weeks ago. Assuming I can find a good one, I'll swap it out and send this funky one back to RockAuto.
· Registered
· Registered
2006 Pilot LX 4WD
Hope your neighbor didn't notice any drops you may have spilled onto his driveway. :p
He was there while I did it, and changed the oil in his Express van at the same time.
We live next door to an Antique Mall and did it while the store was closed.
I wiped up the little bit I spilled, he managed to somehow flip his drain pan pulling it from under the van. :rolleyes:
· Registered
Ha, my F.I.L. did that couple weeks ago in my garage changing the oil in his venza. I put kitty litter on it, then before I could sweep it up my wife parked the pilot full of snow on top and it all turned to disgusting oil litter slime. Was not fun cleaning that up so I could do the work I needed on the Pilot a few days later.
· Registered
2006 Pilot LX 4WD
He was laughing at me wipe up the little bit I spilled when he dumped his drain pan.
My mess got wiped up with a couple paper towels, his was all 6 quarts.
· Registered
Remind me not to post pics of my garage still a full year after my daughter's oil was changed in there. Fortunately, it's a private garage so I'm the only one who has to see that reminder remainder of a precious father-daughter moment. :)
· Registered
2006 Pilot LX 4WD
That reminds me of the time the Stepson kept adding oil to an 85 Olds Cutlass wagon without checking the dipstick because the oil light came on. It overflowed a 15 quart oil pan when I drained it. Not sure how the engine even ran with that much oil in it. Not even sure how many gallons he had put in. The oil sending unit had gone bad.
