1 - 15 of 15 Posts
Has anyone else noticed that water does not drain well from the body of the Pilot? We've had some rain recently and I've noticed a lot of water dripping from the body up to 24 hours later. The day after driving in the rain when backing out of my sloped driveway a large amount water drips out. This seems to me a big potential rust problem especially with salted roads in the winter that we have here. I haven't tracked the exact location of the accumulated water yet.
Are you sure it's not the condensation from the air conditioner?
Chris
I think you may seeing the water condensation from the AC ... It is pretty excessive, but the AC kicks butt ...
PrG
A coat of Zaino will solve that problem. Water will just rolls off your Pilot.
The air conditioner is another story - Don't Zaino your air conditioner!:rolleyes:
dsmith,
Check out my pictures in Arizona Monsoon Season
My Pilot was soaked in water, from the rain and from the flood.
On the next day, the Pilot was fine. No drips of water or puddles.
I believe xyzzy and PrG are right. It's the condensation from the Air Conditioner. Which is normal, especially under humid conditions.
:4:
Discussion Starter #6
Not the AC
I've seen the water condensation from the A/C. That was located closer to the center of the vehicle. This dripping the day after the rain was located on both sides about tire width. I'll keep my eye on it and see if I can track it down any further.
Re: Not the AC
Just out of curiosity, does anyone notice A/C condensation coming from 2 spots - 1 towards the front and 1 towards the center? I noticed it right after we brought ours home and was installing the running boards. Was a little concerned at first, but then drove out to get some lunch and came back and both spots were dry.
I thought I read somewhere that the A/C actually has 2 seperate condensers - one in the front under the passenger side of the dash, and 1 underneath the center console for the rear A/C. If that's the case, then 2 drips would seem logical?
Re: Re: Not the AC
Yes, I have two water spots and I've heard the same explaination.
Chris
Not A/c condensation
DSMITH is right I noticed every time I wash it, Always when I open the gate after few hours a lot of water is coming around the gate gasket not inside but out side, also on the edges of the rear window after you washed or rain water still there check out. also on the doors.
Water not draining from roof
I noticed water dripping the edges of the rear window after washing and drying the Pilot.
It rained here for couple of hours today. The water poured down from the roof when I backed the car after the rains had stopped. Seems the roof is not sloped to drain the water.
Drain
There is a service bullitin somewhere in here about plugging the freight holes in the frame. Check it out, It shows the location of the holes. Supposed to be done at the dealer.
Re: Drain
Anyone have a link to the bulletin?
1 - 15 of 15 Posts
