Hey guys I’m new tot his forum and as I’ve worked on my wife’s 2006 4WD pilot it has been very helpful. I’m running into a few different problems. If I could get your help that’s be great! First issue. I just replaced the VTM4 fluid, new crush washers and fluid from the dealer. When I took the drain plug out there was quite a bit of metal shavings in it. Which is not good. Anyways I put new fluid in put 35ft pounds on the bolts and had the computer reset. Now the light came back on. Not entirely sure what to do.
My second issue is this the check engine light. New iridium Bosch plugs and NGK ignition coils. Torqued the plugs to 13ft pounds.
Changed bank 1 sensor 2 (after the cat) and that issue went away.
hopefully I’m getting to the point here. Does the computer need to work itself out or do I have a timing issue? Any help would be great thanks!
