I started my 2010 Pilot EX-L this morning for a second time and the VTM, VSA and Check Engine lights all came on. I drove about a quarter mile and turned it off and sat for about 2 minutes. When I started it back up only the check engine light stayed on. I drove it about 25 miles to work and the light stayed on the whole time. Not sure what I should do. Any insight would be greatly appreciated.
Go get the codes pulled to find out what's going on. Head to the nearest autozone, OReillys, ect.
Sent from my SM-N950U using Tapatalk
Pull the #4 spark plug and take a look. More than likely fouled. How many miles do you have on them?
If your spark plug is fouled more than likely your piston rings are bad.
Check to see if there is a warranty extension for your piston rings.
I have replaced piston rings on Pilots that had over 100,000 miles because the warranty states 8 years unlimited miles from original purchase date
This just happened to me as well on my 2011 Honda pilot EX-L. I got the codes an they were PO-306 misfire and random misfire the auto zone guy said it was the camshaft positioning sensor. Does this sound right? I am also wondering were this is located on the engine?
