2008 pilot with 151,000 miles and it runs great.
The dash lights VTM-4, VSA, ABS and /!\ lights came on all at once and stayed on for a few days, then went out. The car ran fine otherwise during this period.
A diagnostic tool found these faults:
ABS TCS VSA
11-1, 25-1, 65-1, 112-1
TPMS
11-1, 13-1, 15-1, 17-1
VTM-4
162-1, 34-1
Diagnostic tool function check of all wheel speed sensors was good and same with the yaw sensor.
Brake fluid was full. Tire pressures are all over 30.
Battery is brand new and terminals are in good condition.
Considering many of these are unrelated I suspect I may have a connector issue, possibly at a control module.
Any ideas?
ABS TCS VSA
TPMS
VTM-4
162-1, 34-1
Any ideas?
You may need to have the valve timing adjusted. We experienced similar symptoms (all warning lights came on and stayed on for a few days and the vehicle ran fine) with our Pilot which has about the same mileage.
ABS TCS VSA
TPMS
VTM-4
162-1, 34-1
Any ideas?
Hi Tom, having the same issue with my 2008 Pilot. Did you figure out what the issue was? Thanks in advance!
