1 - 10 of 10 Posts
2005 Honda Pilot Ex
Hi guys searched around the forums for a while but my situation is a bit different than what I read about.
Start the pilot and the light is not on
Move forward or reverse over 5mph and the vtm-4 light comes on.
I am getting vtm-4 codes on my autel scanner Lf wheel speed sensor.
Replaced both abs sensors, vtm-4 fluid, atf fluid, differential temp sensor as well.
When I do a live data all wheel speed sensor report speed accordingly. Where do I go from here?
Welcome to the forum.
What diagnostic code numbers are reported?
According to FSM:
If 22-1:
Sensor defective (but you verified good)
Open or short in wire harness (but you verified speed is reported correctly)
VTM-4 control unit defective
ABS modulator defective
Reactions: plplplpl
2005 Honda Pilot Ex
When I scan for fault codes in the abs system I don't get the speed sensor fault only when I scan in the vtm section.
I will try replacing the vtm-4 module next.
Does it drive any differently?
I don’t recall seeing any posts over the past five plus years where someone has replaced the VTM-4 module. I’d check the wiring on its harnesses first, followed by connector pin integrity.
Reactions: Cobra98951
2005 Honda Pilot Ex
2005 Honda Pilot Ex
I'll check this out I already ordered a 2md hand module. So I'll try this 1st then the egr to see which one did the trick.
Let us know how it goes. I’m curious what you find out.
1 - 10 of 10 Posts
