Welcome to the forum.
Potentially lots of faults can cause those two warning lights to illuminate. The first step will be to get the codes read then report back here.
Reactions: MindOfJory
As said, many things can cause that. It just happened to me on a test drive. But it was due to my haste in changing a rear axle and I must have stretched the ABS wheel speed wiring. Fault lights and coded (right rear ABS open circuit or disconnected), Learned the hard way.
If you don't own a scanner the local auto parts stores like Advance/Autozone can scan for any code(s) present. This could identify whether it's a wheel speed sensor and which one.
