Hey guys, ive recently done some work on my 2008 Honda Pilot, and and now the VSA light keeps coming on.
I replaced the wheel bearings, tie rod ends, lower sontrol arms and stabilizers, also one of the ABS sensors becasue I broke it while working.
But now when I drive after about 30 seconds of the car running, the VSA light turns on and doesnt turn back off until the car is turned off.
Then it starts with it off, then after about 30 seconds it turns on and stays on again.
Just wondering what I need to do to get it running right.
Also... My "Brake" light keeps flickering, not sure where the sonsor is to have a look at.
Any pointers would be greatly appreciated.
Thanks guys.
I'm going to say look long and hard at that ABS sensor again. Did you replace with OEM? Even so, you might need an HDS (typically only at the stealership) to reset.
what do you meant by look long and hard at the ABS sensor?
What should i be looking for? It was replaced with OEM.
Would not a good sensor fix it, would I still need to reset it with a HDR?
