I have a 2006 honda pilot. recently, after car repair, the vsa and triangle light will not go off. scanner shows 0 code issues. Issue does not affect driving but is annoying.
I could change out switch but with no code showing that may be a waste of money. Any suggestions?
Find my topic on that, it explains everything about the VSA neutral position reset procedure. Called something like "Got ABS, VSA and the dreaded triangle."
also pickup a scanner that can scan ABS codes
i picked up a scanner. it showed 0 codes?
You have an OBDII scanner which reads the ECU/PCM, but Tahoefever suggested that you buy one which also shows the ABS/VCM/VTM-4/SRS codes.
