I was stuck in traffic, I push fuel quickly (full push) when the road is open and check engine start blinking and I felt some vibration and the pilot was not normal. I turned the engine off for 3 minutes, back on and everything back to normal.
Please advise
Hello,
It would be neccessary to get the trouble code(s). Do you have an OBD II scanner?
Please advise
I have the same issue. Its a recurring problem in that scenario. I haven’t had it checked yet but my opinion is it has something to do with the VCM.
Guessin, but by far most likely is cylinder misfires caused by cylinder ring damage from vcm. Replace spark plugs, put a vcm disable device like svcm on it (google will take you to their site) and hope for the best. Also pulling codes using a scan tool will prevent parts cannon guessing… though I bet I’m right.
