1 - 20 of 169 Posts
Over that past few months I have been disliking driving my pilot for only one reason....the armrest. I pretty much like everything else except maybe for the sound quality of the audio and the lack of bass. There was a site that I came across that had a way of possibly modding the armrest and making it much more comfortable to drive. Is anyone in the NY/NJ area that has heard of this company or may be able to take a look? They said they may be able to make the first of its kind modification for free.
If you take a look at the Toyota they have a Wide Armrest which looks so much more pleasing and he mentioned to me that it would not be a ratchet type where it clicks, but instead only an up and down.
JJ Products 1-800-654-2356 | Armrests | Rear Seats | Upholstery | Dash Kits | Wind Deflectors | Bug Guard
here is the Toyota/lexus pic
Lexus RX Armrest | Toyota Highlander Armrest | Wide Armrest | Dual Armrests | Two Armrests | RX300 | RX330 | RX350 | RX400h | RX 300 | RX 330 | RX 350 | RX 400h | Extra Wide Armrests | Driver Armrest | Arm Rest | Aftermarket | Extra Large Lexus Armre
Good idea. I just E Mailed their customer service dept, They have them for the CRV.. Maybe Ill get an answer
I totally agree with you about the arm rest. It is very uncomfortable. I would be very interested in this product if it is reliable and effective. I miss my 2009 Pilot which had a beautiful, big arm rest you could rest your arm on.
I got this reply just now from the company..
Not yet. I'm working on it.
If you live in NJ would you be willing to help?
Thanks,
Jim
1-800-654-2356
Guys if you search for armrest you will find I have been contacting Jim for a while now.
He needs someone to open up the zippers on the drivers side seat and see if the armrest clicks into a piece that is welded to the seat or if it is bolted to the seat.
If it's bolted we can use his custom bracket to get armrests made. BUT if it is welded we are $.hit out if luck.
I haven't had the time to open up my seat and take some pictures where the armrest is inserted.
Can anyone do this? I planned on meeting up with him but can't until he knows how it is attached.
http://www.piloteers.org/forums/showpost.php?p=982178
Well, the padding in the front of my armrest, where I rest my elbow, has now compressed to nothing. Its "leather" on hard plastic. I'm willing to be a bit proactive and explore the guts of the thing if there is some hope of a resolution. I haven't wrecked anything expensive in at least a week...
If you can confirm that the part that the sprocket "slides" into is not welded on I can have Jim fabricate us new armrests and will meet up with him for testing fitment etc.
It is all dependent on using his custom mount which means we would have to take off the OEM bolt and replace it with his - that's why if it's welded on the whole operation is a no go. If you can unzip both zippers on the back of the drivers side seat (carefully) and reach up towards the armrest and feel or even get pictures that would be amazing.
I'm in NJ and would be willing to meet up with Jim if someone can confirm sprocket type. If he can it'll be a meet up in my neck of the woods 👌
Here are some pics of the armrest bracket. May not be good news. There is a bracket welded to the side of the seat frame, and a plate screws into that. ( 5x16 mm tapping screws, from parts diagrams ). On my Touring, the plate houses the ratchet assembly, so this may be of interest to anyone who wants to add that feature. I was struggling to hold back some foam while I snapped these pics with an iPhone. If I can figure out how to pull off the armrest and improve access, I will try again.
Thanks for taking those pics. Let me talk to Jim - I will PM you with my email address - maybe you can send me the hi-res pics that aren't compressed. And if you can take the armrest off and get some better pictures also that would be a HUGE help!
And I can teach you how to take the armrest off. It took me an hour to figure this out. You need to put the armrest to 37.5 degrees from the resting position. I was out there with my protractor and everything. It took a while but you just pull on it. Grab the lowest part of the armrest and just pull it straight out. I counted 12 stitches from the cross stitch. Here's a hi-res shot.
Banned
I'd prefer a center/padded console accessory that will fit over the existing console for both front and middle row captain seats.
Anyone going to offer an after market accessory like this?
I don't even use my cheap/way-too-narrow armrest anymore.
I leave it up and out of the way altogether.
Jim's armrests will be wider and if you replace both drivers and passengers it will be like one big armrest (provided you keep the ratchet drivers side the same height as the passengers). Actually I think the Elite armrests ratchet on both sides.
Yes, Touring and Elite ratchet both sides. I just spent another half hour tugging and cursing and I can't get either one to release. I knew about the 37 degrees from the online manual I spent 10 bucks on for today, and I tried your picture as a guide but I still can't get it.
Btw non-ratcheting should be easy. Just pop off a cap and unscrew a nut. Armrest is different too, not just ratchet mechanism.
Pull straight out horizontally away from the side of the seat, right?
Yes I put the e-brake on because I was shaking the car and literally it took me an hour because the 37 degrees was tough to tell where to measure from so I tried every angle starting from down working up every centimeter or so. You have to pull very hard straight away from the seat. I moved the passenger seat all the way back and put both my knees on the passenger seat facing the drivers seat and started tugging hard. You have to pull very hard. It won't break the armrest - I put one hand on each side of the circular piece closest to the seat and started tugging. I was sweating by the time I got it out.
Use my picture as a guide for where to start - I think it was 11 or 12 stitches down the upholstery on my car. I took a picture (that I attached) when I popped it back in before I moved it so I would remember for the future.
You know what I just looked at my picture again and my seat is a little bit reclined. Obviously if your seat is completely straight up and down your armrest is not going to face exactly where mine is pointing. Not sure if this might have been overlooked as I just realized that myself.
Yeah. I was going by the horizontal stitch line as a reference anyway. I probably wasn't pulling hard enough. I will try again.
Mine is compressed anyway, so worse case is I break it and it gets replaced.
I don't think you'll be able to break it as it is injection molded. I was tugging on it with a lot of force and it never budged until hitting the sweet spot. Then it popped right out and I went falling backwards a little bit like tug-of-war and the other side let go of the rope.
1 - 20 of 169 Posts
