I've noticed if I hit "off" on the climate control I still get air flow through the center vent. I also get air flow from the center vent when the "mode" is set to floor. Is this normal?
The only way you can completely cut off outside air from coming in through the vents, even if you have the climate control off, is by having the recirculation on by pressing the button for that. Otherwise, the outside air's going to come through the vents in the mode it was in last before you press OFF. Also, you can control the mode by pressing the button even with the climate control off.
