I've owned a 2011 Pilot for about a year and a half. Recently while on a trip the plug on cylinder 3 fouled and caused an misfire error code. After reading up on the problems with VCM, I pulled all of the plugs to examine them. Plugs one and two were pretty clean, almost as clean as the front bank which looked very good. Plug 3 had some carbon buildup. The gaps and wear were .043 - .044 on all of them. I wiped and sprayed plug 3 with brake cleaner and cleaned any loose carbon off with and abrasive pad and a fine wire brush. Then I blew it off with compressed air. I switched it with the plug in cylinder 4. I drove it for 40 miles and did not get any misfire or error codes. After the engine cooled I pulled both plugs and looked at them. They didn't look any different than before. I switched all the plugs from front to back bank and will run them for 7500 miles to see if rotating the plugs at oil change or at some interval works to manage carbon deposits on the plugs.
Has anyone else tried this? If so what were your results?
The problem with VCM misfires seem to be related to running in econo mode for long periods. Has anyone experimented with running a timer to disable it for short periods to act as a cleaning cycle? I don't see the need to disable it completely when periodic cleaning manually, plug rotation from front to back banks, or with a timer would work.
7/13/2022
I purchased a ultrasonic cleaner from Harbor Freight and ran the spark plug from cylinder #3 through it for a total of about 20 min. (read the instructions carefully before using it or you may burn it up or hurt yourself) After cleaning, the electrode insulation ceramic showed surface cracks that caused me to believe that examining all 6 was a good idea. One other plug showed similar cracking. I decided that replacing all 6 was a good idea. Maintenance records from the dealer made no notes of plugs ever being changed(vehicle miles 92,500). Rockauto has a good selection. I went with a set of NGK Ruthenium HX, LKR7AHX-S, 96358. The plugs have been in the engine since Sunday 7/10/2022. No problems so far. I also ran a container of Chevron Techron Concentrate Plus Fuel System Cleaner - 20 oz. through the last tank of gas.
Oil used since purchase, up to last oil change, is Castrol Edge High Mileage synthetic 5w-20. Oil used at last oil change at 92,200 mi. is Mobil 1 High Mileage Full Synthetic Motor Oil 5W-20. I used Mobil because I was shopping at Bi Mart and they were out of Castrol. The filter was changed with each oil change.
Monday 7/25/2022 - Mileage 93,600. No misfires. I drove From N. Portland to Hood River Saturday morning. There is some summer construction going on as usual so the posted speed limits were 50-65 mph. Traffic was light and was moving 55-68 mph. Temperature was 65 deg. MPG was 26.8 on that stretch. Coming back Sat. afternoon the temp was 90 deg. traffic was ok until about 15 miles from Corbett when the Sunday night trucker rush slowed traffic to stop and go crawl for 15-17 miles. I pulled off at the Dalton Point boat ramp for an hour until traffic lightened up, and was moving at 30-40 mph. MPG was 23.1. Overall mileage was 22.3 mpg for the whole weekend. About 170 total miles traveled. Driving off the interstate was along WA 141 along the White Salmon river.
12-17-2022 Saturday
Regular service
No misfires or other engine problems. I replaced all 4 tire pressure sensors. The RR tire had a low battery. That project took about 5 hours. I used OEM parts from Rockauto.
I completed the 100,500 mile service. While doing it I endoscoped cylinders 3 & 6. Cylinder 3 runs dirtiest, and 6 runs cleanest. I swapped the plugs with each other and will look at the dirty plug I put in cyl. 6 after a week or three and see it has cleaned up any.
Here are the endoscope photos. Cylinder 6 piston is a bit cleaner.
Cylinder 3
Cylinder 6
Addendum: After getting too many people trying to sell me on the idea of going directly to installing a Muzzler or similar device, I ask those people to pass on joining or commenting in this thread. My interest is in keeping my Pilot running as designed as much as possible. I believe, at this time, that the issue with my Pilot can be managed by following a maintenance schedule that keeps carbon buildup away, using quality oil, fuels, and additives. Oil usage between changes is negligible. A VCM disabler is a last resort.
7/13/2022
12-17-2022 Saturday
Regular service
Cylinder 3
Cylinder 6
