1 - 15 of 15 Posts
So, the stem caps that came with my 2020 Pilot are plastic but simulate being aluminum, and have a “N2” logo (the dealer filled them with Nitrogen, which honestly I don’t care about. Next time “regular air” will be). Looking to replace the caps just for the sake of getting rid of that N2 logo.
I believe the metal caps are not recommended due to corrosion (and the last thing I want is to worry about applying lubricant when I check the tire pressure). Does this mean the best alternative is to use the typical 30-pack of regular plastic caps that can be found anywhere for like $5?
Thank you!
Ours just has regular old plastic caps.... the tire place always seems to install new ones when we get tires and they have to replace the TPMS sensors seals.
Don't fall for the metal caps trap which look awesome but the corrosion is no joke! Even with pliers I couldn't get that corroded aluminum cap off the valve stem. I stopped trying to twist with pliers when the valve stem started to twist and rip. Save them for the kids bike LOL
usually when they fill them with Nitrogen they are supposed to be replaced with a green cap this tells the tire guy that these are not filled with regular air.
Does it matter if you fill them up with regular air? Because at some point I’ll have to do it for sure (I check tire pressure every 4-8 weeks).
I use a special gas in my tires, it has 78% nitrogen, and blends with anything already in there.
Reactions: bradster and aggrex
Discussion Starter · #11 ·
That’s where I was going... I couldn’t care less about nitrogen, but the car came with that as an extra. The first time I fill the tires I was planning on filling them with your special gas too :)))
yes those are cool ..
Premium Member
I might have to order a set of those.
1 - 15 of 15 Posts
