My Pilot won't "flip/flop" the air flow between the upper vents and lower vents. There are 2 motors on the passenger side. The lower motor is somewhat easy to remove. The upper motor has failed because when pressing the "Mode" button, I can't re-direct the air flow to the lower floor vents. I've gotten 2 of the screws removed for the upper motor, but the third one is semi-blocked by a pipe. I can't get a screwdriver or 7MM socket onto it to remove. There must be some trick to removing the upper left screw on this motor.
Anybody have an insight or videos to help me? The only thing I can think of is to remove the passenger side dashboard so I can use a long Phillips screwdriver to remove the screw.
Anybody got an info, diagrams or video to help?
