Upgrading TrailSport audio (but keeping the head unit)
1716 Views 11 Replies 7 Participants Last post by  infantry200505
I wish the TrailSport had the upgraded audio system found in the Elite/Touring. It looks like the enhanced system has better speakers and some sort of secondary sub. Unclear if the head unit has how power. I'd like to upgrade the system but keep the integrated head unit as is, and not reduce interior space by adding big sub boxes, etc. OEM systems have gotten so good over the years that I haven't played in this game since the 90s. Any thoughts or recommendations? Thank you for your guidance.
1 - 12 of 12 Posts
You can learn alot in the gen3 forum that will almost surely apply to gen4. First step is to disable ANC (automatic noise cancelling) - removing the unit that usually sits behind the glove box seems to be the best method. Going from memory, the base unit for gen3 was amoplified in the head unt (so use a line converter) and the Touring/Elite system had a separate little amp.
I never upgraded my 2017 EX-L, but plan to upgrade the Trailsport. I plan to make a removeable sub box to fit between the two rear seats. May build a tray on top for junk.
For a quick refence, here are some converters:
Speaker level to line level converters
There are some that add equalization. Someitmes the amp has equalization.
How is the stock audio system in your EX-L? Debating if it's worth the upgrade.
It stinks. I had just upgraded my home system, so I lived with it.
Reactions: 1
I just upgraded the audio in my 2023 pilot exl it was prettt awful in my opinion. Replaced all speakers and tweeters and added a single 12 inch subwoofer. Made a huge difference in the way it sounded and was pretty easy to do overall.
White Light Automotive tire Black Automotive exterior
Automotive tire Motor vehicle Rim Automotive exterior Automotive design
Tire Automotive tire Automotive design Motor vehicle Automotive exterior
Automotive tire Camera accessory Grey Cameras & optics Rim
Hood Automotive design Automotive tire Motor vehicle Bumper
See less See more
5
It was awful in my opinion. Upgraded my doors speakers and tweeters and added a single 12 subwoofer. In the next few weeks I will be adding a 5 channel amp to power everything with keeping the factory head unit. Door speakers were 6.5 and the 1 inch tweeters I got fit right into the Honda tweeters grills.
This is more of a curious question, how do you tap into factory harness? I don’t think adapters to fit the oem connectors are available yet.
p.s. my experience is beginner/crutch field level
If there’s no adapters you’d have to cut and splice them in. I’d wait personally in case you ever want to go back to stock and sell the car but that’s just me.
No adapters available yet. I used the Honda speakers spacers that were in my 2021 passport they fit no issues. I plan on keeping this pilot once the lease is up.
I will likely be doing the same thing. Replacing all speakers and a sub with a 5 channel amp. Do you have a write up on how you did it? What components did you use?
Reactions: 1
I just hooked up my mono amp an sub for now until all data has the wiring diagram for the factory head unit
Reactions: 1
1 - 12 of 12 Posts
