Hi, I am new here so if this topic has been covered here please let me know. All threads I have come across are speaker upgrades to EX/EXL. My understanding is the Touring/Elite have a higher power amp so I would want to get appropriately spec'd aftermarket speakers & tweeters.
Another curve ball is the another sticky thread specifies the impedance on the touring tweeters to be 4ohms. I removed an A pillar and the back of the tweeter reads 2ohms (Pic will be added). That makes me wonder is Honda changed the audio setup on 2019s.
That said, I would like to spend too much on the speaker upgrade. Its a road-trip car and not my daily driver. I would like to upgrade the tweeters, front doors and may be the rear doors if components chosen are not to pricey. Also wondering if I should upgrade the center channel. It appears to participate rather passionately in any activity the sound-system partakes.
Anyone having a good recommendation on component speakers which are a good bang for the buck will help. Also, any specific info regarding 2019 touring/elite speakers will be helpful.
Thanks,
Discussion Starter #2
So Far I am leaning towards Component speakers in the front doors and locating their tweeters to A pillars with a passive hi-pass filter inline with wired already going to oem tweeters.
For rear doors, I can get decent coaxial (or should I put components) from the same manufacturer/series.
I am inclined towards upgrading the center 3.5" speaker ideally with a band-pass for clear vocals.
I will add sound deadening where I can while the panels are open. Also plan on using metra speaker harnesses and speaker brackets.
I would not want to upgrade the factory amp or subwoofer.
If someone knows of a good set of components/coaxial that will match up to the what honda says is a 590W factory AMP, please chime in.
As of now I am looking at Polk Audio DB6502 OR Infinity Kappa 60.11CS for components.
Not sure whether you've watched this YouTube
He installed the Infinity Kappa 60.11CS with the inline Crossover form JBL GTO19T tweeter
