for pilot 2013 - on a number of occasions, when i turn on my A/C, the recycled air button also turns on. Thats the way i like it, but then now it does not do it. I have to turn the A/C and then manually turn on the recycled air. How do i get A/C and recycled air come on together? thanks
If my ac cabin temp is set below 70f then both come on in my 2012. If set above, I have to press the recycle button.
The controller is pretty smart in Auto mode. When it decides that you really need a maximum cooling effort, it will select the recirc mode since it will cool the cabin faster. Once the temp balances (inside vs. outside. vs. target setpoint value) get right side up, the system will drop recirc mode and bring in fresh air again.
